My pirate R32
Diskutiere My pirate R32 im Mein R32 Forum im Bereich Golf 4 R32; Nice, Top App :great:
  • My pirate R32 Beitrag #101
Karli
Karli
  • My pirate R32 Beitrag #102
Alexi
Does anyone know brakers from Germany/Austria etc? I need 1j1971090HN.... Its second loom for ecu...
  • My pirate R32 Beitrag #103
Alexi
I got the pistons and rods...
Now the engine is on machineshop...
Now i just need to wait...Does any one know good valvetrain for R? Ferria?
  • My pirate R32 Beitrag #104
Nice Parts!! :great:
What do you do with the Motorblock ?
  • My pirate R32 Beitrag #105
Alexi
The bore will be + 0,5mm and hone on stress plate. Crank, rods and pistons will be balanced, arp main bolt kit so crank line must be hone. They will also intall bottom end (pistons, crank, rods, bearings). I dont want to play with those, because of tolerance...Compression should be around 11,6 or 11,7:1
  • My pirate R32 Beitrag #106
Alexi
Fail---> I forgot the plate behind of sprocket.
New try:
Sharp teeth show correct:
Sprockets teeth lines up.
Also dampers mark is on correct.
Pistons are like this on those marks:
Cams are correct position:
Upperchain, lower sprocket:
Didnt found any info on this, but maybe its correct.
I turned cam sprockets to inlet way, like to open bolts.
Lets hope this is correct.
  • My pirate R32 Beitrag #107
wow :great: most people in here will understand your pics but not english language in detail *noahnung*
It is very special stuff and it seems you need an expert for assistance 8)
  • My pirate R32 Beitrag #108
Alexi
Thats true, but its difficult to find correct words for german. Well i think chains are correctly installed, but it would be nice if someone could confirm this.
Könnte jemand dafür sorgen, dass die Kette richtig installiert ist?
  • My pirate R32 Beitrag #109
Kann jemand dem Alexi helfen? Ist die Kette so richtig eingebaut?
  • My pirate R32 Beitrag #110
Contact HCMP:great:
  • My pirate R32 Beitrag #112
oh nice, a pulley kit. :great:
I want that on my car too.
But in germany we only get 3 pulleys.... :(
Whats on that pic left from the pulleys ?
  • My pirate R32 Beitrag #113
Alexi
Its bracket (holder) for electric water pump. I bought just tension and waterpump pulley. Didint want to replace damper or alternator pulley or go underdrive steering pump.
  • My pirate R32 Beitrag #115
YES.
almost done? :D
  • My pirate R32 Beitrag #116
Alexi
Yep almost. Where you guys get software for ECU? Seems pretty hard to find....
  • My pirate R32 Beitrag #117
Karli
Karli
very interesting facts:great:
  • My pirate R32 Beitrag #118
Alexi
Changed fuel pump today.
  • My pirate R32 Beitrag #119
Alexi
Still waiting waterhoses, after 2,5 moths.....
I found funny pic from last winter, this is what snow and low car does....
  • My pirate R32 Beitrag #120
Hahaha - aerodynamic :great:
My pirate R32
J_U_K_I
2 3
J_U_K_I
J_U_K_I
UniniC1992
